mickgibs
Apr 24, 2019Initiate
Orbi wifi dropouts
Hi folks,
I promise I've searched the forum before posting this, as I know it's similar to other posts, but I couldn't find anything that would help.
I've had the orbi RBK50 system for ab...
Apr 24, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- mickgibsApr 24, 2019Initiate
Are you serious?
It's going to take my whole afternoon to troubleshoot that?
Jesus Christ.
Perhaps I'm better off raising a support case with Netgear directly?
Regards
Mick
- plemansApr 24, 2019Guru - Experienced User
FURRYe38 has went through the basic troubleshooting for the Orbi. If you've searched the forums, you'd have read this several times. Its 101 for making sure the orbi is setup and not having interference issues.
Its surprising how many issues can affect wireless network performance and whats needed to optimize it. It was much simpler when wireless first came out and there wasn't as many devices broadcasting on it. In the current generation, you need to do some basic troubleshooting before assuming a device is bad.
- michaelkenwardApr 25, 2019Guru - Experienced User
You will probably get the same advice.
As plemans confirms, these are standard troubleshooting steps.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Bedtime reading?
- FURRYe38Apr 25, 2019Guru - Experienced User
NG support will have you do the same thing.
These are tried and tested troubleshooting steps. I understand your frustration and the system should work, however when it comes to wifi, there are MANY variables to wifi and causes of wifi not working well. There is NO one fix all for this. Nature of the beast. Some of us have been doing this for a while. :smileyfrustrated:
Please give feedback to the questions presented as this will help us here in the forum get a better idea of what is going on and what you have. Try some of the suggestions. You may find someting that helps. :smileyhappy:
mickgibs wrote:
Are you serious?
Jesus Christ.
Regards
Mick
