DKBKNY's avatar
DKBKNY
Tutor
Jun 27, 2020
Orbi WiFi Extender RBS50Y
I am considering purchasing the orbi WiFi Range Extender RBS50Y and wanted to know if this is compatible with my Verizon Fios router or do I need to purchase an additional Orbi router.  Thznks.
  • FURRYe38's avatar
    Jun 27, 2020
    The RBSY has two modes, Orbi mode and Extender mode. If you install the extender mode FW, then it would connect to your exisiting wifif router.
