TerryTuohy
Jan 19, 2023Aspirant
Orbi WiFi extender
Is the password on bottom of Orbi the only option to setup? And can it be changed? Daughter trying to hook up Orbi I gave her and struggling to get it to connect 🤔
michaelkenward
Jan 20, 2023Guru - Experienced User
Which Orbi?
There are two "passwords", one for the router and one for the wifi.
Both can be changed.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
