kdeemer
Dec 22, 2016Tutor
Orbi wifi extremely slow to connect
I have the three node Costco system and am getting very good coverage in my home. A speed test shows more than 50MB up and down. But when I try to load a web page or a video, it is painfully slow. S...
DarrenM
Dec 28, 2016Sr. NETGEAR Moderator
Hello Kdeemer
What Firmware are you on I know of some issues with IOS devices on .18 you may want to go to the .16 firmware and see if that resolves the issue.
DarrenM
- JMU1998Dec 28, 2016Luminary
is netgear aware of the inconsistent and unstability for iOS devices? Will this be addressed in next Firmware? I have to reboot frequently to maintain stable connections on iOS devices, this not expected from a $400 router.
- Hydro130Dec 28, 2016Luminary
I have a iPhone SE and iPhone 6 (both on 10.2) in addition to a couple Apple laptops.
With the Orbi, I've never noticed a dropped connection or slow speeds on any of those Apple devices (or any other devices).
I am curently on the latest f/w for the Orbi - evetrything is working consistently at best speeds (provisioned + ~20%).
