kdeemer
Dec 22, 2016Tutor
Orbi wifi extremely slow to connect
I have the three node Costco system and am getting very good coverage in my home. A speed test shows more than 50MB up and down. But when I try to load a web page or a video, it is painfully slow. S...
DarrenM
Dec 28, 2016Sr. NETGEAR Moderator
Hello Kdeemer
What Firmware are you on I know of some issues with IOS devices on .18 you may want to go to the .16 firmware and see if that resolves the issue.
DarrenM
JMU1998
Dec 28, 2016Luminary
is netgear aware of the inconsistent and unstability for iOS devices? Will this be addressed in next Firmware? I have to reboot frequently to maintain stable connections on iOS devices, this not expected from a $400 router.
- Hydro130Dec 28, 2016Luminary
I have a iPhone SE and iPhone 6 (both on 10.2) in addition to a couple Apple laptops.
With the Orbi, I've never noticed a dropped connection or slow speeds on any of those Apple devices (or any other devices).
I am curently on the latest f/w for the Orbi - evetrything is working consistently at best speeds (provisioned + ~20%).
