AC16's avatar
AC16
Follower
Sep 06, 2020
Orbi wifi is half the supposed insternet speed
hi guys, I recently upped my xfinity internet from 175 to 600 mbps. My modem is Motorola mb8600 (replacing arris sb6141 after upgraded plan) and router is RBR50. Speed test through orbi app is showing 600+ but when it comes to ookla speed test, I only get 250-300. WiFi speed are pretty consistent around the house at that speed. Orbi firmware V2.7.0.70. Just wondering why the WiFi speed is half of the supposed internet speed and is it normal?  Thanks
  • FURRYe38's avatar
    Depending upon your device your speed testing with, most wireless devices may max out at around 400mpbs. Based on designed and support of the device.
    Other factors are noise around the Orbi system, configuration and ISP modem as well.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    What are your wired speed results with a wired PC connected to the RBR?
    Do you have Armor or Cicle enabled?
    Has a full power OFF of the Orbi and ISP Modem for 1 minuted then back on been performed since last FW update?
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Ookla is going to give different results depending on what server you connect to. Try your ISP speed test. They, even though they may use Ookla, will usually give you a more accurate reading, as the ISP will have a designated server picked.
