Tcrus
Nov 01, 2017Luminary
Orbi WIFI keeps dropping out???
I have had my ORBI (base sat+2 sats) system 6 months and it ran so smooth. Now I am experiencing WIFI drops multiple times a day. My firmware is up to date. Anyone else having this problem? There is ...
Orbicustomer
Nov 05, 2017Initiate
My ORBI was great for several months and has just gone to hell over the last few days. Reading this thread seems to indicate that the latest update created some major problems. I have to reset my modem and ORBI frequently and it still often stops working.
- AkoliteNov 06, 2017Tutor
I got simlar issues. Router reboots every 4 to 6 hours roughly. Its 3 days old...
- ChazsmlNov 06, 2017Initiate
Same issue. I am all Mac and IOS. I replaced Eero with Orbi because Eero was dropping, they acknowledged they had Mac and IOS problems but never could fix. After 2 months of wrestling I threw in the towel for Orbi ( The Best ) Only to find having same issue. Stays up for a while then hangs reboots, Magenta light etc. So frustrated. 2 calls with support changing channels turning on implicit mode etc. Doesnt seem to work. Tech advised may need to swa hardware which franklly doesn't seem to make sense. There is an underlying problem with these mesh systems in my opinion. If no solution I will return. Hoping there are answers coming on this forum.
- OrbicustomerNov 06, 2017Initiate
My ORBI is working fine now during Monday business hours. Is there another neighborhood ORBI user that affects my system? I don’t know, but I’m far from other homes.
- OliverpoolNov 06, 2017Guide
Orbi is totally unreliable FULL STOP. They do not even allow you to stay on a older version as the router keeps insisting to upgrade to the lastest without asking for your permission!
- petertsJan 22, 2018Tutor
same issue as everyone else. router worked for 2 months now constant wifi drops using ethernet backhaul can't get it to sync wirelesly anymore
