Tcrus
Nov 01, 2017Luminary
Orbi WIFI keeps dropping out???
I have had my ORBI (base sat+2 sats) system 6 months and it ran so smooth. Now I am experiencing WIFI drops multiple times a day. My firmware is up to date. Anyone else having this problem? There is ...
thevans4
Jul 02, 2018Aspirant
I returned the Orbi I had originally purchased to Amazon, and switched to a Google system.
I have not had one problem with the Google, no dropouts, good speed abd super easy setup.
Phone compatible Wifi app- super easy to use.
Fully recommend.
Tcrus
Sep 04, 2018Luminary
Problem is back! I dont know why and what to do about this. Dropping out 5-10 times a day.................................
- FURRYe38Sep 05, 2018Guru - Experienced User
What FW is currently loaded? Have you asked for the new Beta to see if that helps any? https://community.netgear.com/t5/Orbi/Looking-for-a-select-group-of-Orbi-Community-members-that-are/td-p/1624103/jump-to/first-unread-message
What is the Mfr and model# of the IP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- TcrusSep 05, 2018Luminary
It was working flawlessly for 6 months or so so that elminates some of the issues you asked about. I did speak with support and they had me change a few things (channels mainly). I will see how this helps. Thanks for the information
IF all else fails, I would ask support for an RMA. You may have a bad system.
