acres44
Jan 29, 2020Aspirant
Orbi Wifi Mesh System RBR20 intermittenly going off line
I have an ATT BGW210-700 in bridgemode to My RBR20. The RBR20 is set to AP mode. The router intermittently goes out and it is too frequent for me. I had to hot fix firmare updated to the current ...
Jan 29, 2020Guru - Experienced User
Crimpon is correct, if you have the RBR in AP mode, then the ISP modem needs to be in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
