YONGSTAN
Apr 22, 2019Aspirant
ORBI WIFI NETWORK NAME
Hi all, I am running on 2GB dual broadband at home, split into two 1GB bandwidth, on RBR50 + Satellite and RBR40+Satellite respectively. Both are currently on different wifi network name. Wanted to...
- Apr 22, 2019
The satellites can mix and match. Only thing to keep in mind is the backhaul for the lower models is only 2x2 and not 4x4 like the rbs50's.
so if you're daisy chaining them, put the lower backhaul device at the end of the chain to limit bottlenecks.
Apr 22, 2019Guru - Experienced User
oh and with your dual hookup, I assumed both had their own IP addresses? Just checking as Orbi has issues with 2 orbi routers on the same network.
- YONGSTANApr 22, 2019AspirantYes. They have their own IP. Looks like its a no go...
- plemansApr 22, 2019Guru - Experienced User
Not necessarily saying its fully no go. You could put all your wired devices on one of the 1gig services so that the other was reserved just for wifi devices. And you can leave the orbi's with separate wifi's. Just make sure to separate out the channels far enough to limit interference if possible. Lots of possiblities for setup and better to have the option than those of us without.
Again, not sure of what the overall intention is to help you figure out a good solution. the seperate IP addresses is a benefit for some (IoT devices, servers, etc) to reduce congestion on one network or for network security. Its a downfall for others as they like all their IP address's in a set range.
Up to you how you prefer managing your network.
- schumakuApr 22, 2019Guru - Experienced User
A router with multi-WAN capability and enough bandwidth can deal with more than one Internet connection - you won't find these in the consumer market. And then, the 1 GbE Orbi wont be able to take a real advantage out of it.
