YONGSTAN's avatar
YONGSTAN
ORBI WIFI NETWORK NAME
Hi all, I am running on 2GB dual broadband at home, split into two 1GB bandwidth, on RBR50 + Satellite and RBR40+Satellite respectively. Both are currently on different wifi network name. Wanted to...
  • plemans's avatar
    Apr 22, 2019
    The satellites can mix and match. Only thing to keep in mind is the backhaul for the lower models is only 2x2 and not 4x4 like the rbs50's.
    so if you're daisy chaining them, put the lower backhaul device at the end of the chain to limit bottlenecks.
