batpot
Apr 22, 2020Tutor
Orbi wifi not visible
My primary WiFi is working - multiple devices are connected to it, but it's not visible, and there's no settings to make it visible. What gives?
Apr 22, 2020Guru - Experienced User
What Firmware version is currently loaded? V16 is available for download.
Is the Orbi system operating in Router or AP mode?
