Orbi666
Oct 13, 2019Initiate
ORBI Wifi Problems
We have had the ORBI wireless system for nearly two years now. One Master and One sattelite. We have had CONSTANT problems with the wifi. We have had intermittent drops for devices, bandwidth iss...
agrince
Mar 13, 2020Aspirant
I have the same problem. I have a main unit (RBK50) with 2 satellites. It worked fine from October 2019 until end of February 2020.
Now, it won't work at all even though it is connected and I got the blue light when I synced.
My modem speed(Vodafone) is 70 mbps at the router, but on my laptop downstairs next to the satellite it is 800 kbps.
We can't get Netflix anymore either in the TV room where the other satellite is..
Does anyone know a better way to extend my wifi to the downstairs of my house? I have wasted days trying to get this to work. Is there some way to diagnose what is wrong? Does this system simply break down easily?
At this point, I just want to find something that works. I don't understand most of what is written in these groups so telling me complicated things to do won't work.
Any help is appreciated.
Geraldine
- FURRYe38Mar 13, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
agrince wrote:I have the same problem. I have a main unit (RBK50) with 2 satellites. It worked fine from October 2019 until end of February 2020.
Geraldine
Has a factory reset and setup from scratch been performed since last update?
- Retired_MemberMar 13, 2020
FURRYe38 wrote:What Firmware is currently loaded?
Geraldine
:smileysad:
- AccordatorepianJun 01, 2020Initiate
Doesn't work,, RBR20 and RNS20 continuos wifi disconnecting.
I have and external modem and Orbies are used only as a router access point and two satellites for first floor
Same home, same base & satellite positions but using Fritzbox 1750 works perfectly.
Orbi guys you design a poor product , change FW if is it possible to recover or dismiss this kind of product !
