BRye
May 22, 2017Tutor
Orbi Wifi Satellite Has a Solid White Light On Top. RBS50
I purchased the Orbi with the 2 RBS50 satellites. Everything was working fine until I moved one of the satellites from one room to another and now it will not reconnect. The light on the top is const...
Streak2
May 23, 2017Master
Did you hold the reset button in for about 6 or 7 seconds until the green power light flashed amber?
