BRye
May 22, 2017Tutor
Orbi Wifi Satellite Has a Solid White Light On Top. RBS50
I purchased the Orbi with the 2 RBS50 satellites. Everything was working fine until I moved one of the satellites from one room to another and now it will not reconnect. The light on the top is const...
Streak2
Sep 04, 2017Master
Jeremy,
When you log into your orbi system http://orbilogin.com/ is it not seeing the RBS50?
How many satellites is it reporting?
If it's not seeing the satellite then have you tried to resync or reset/resync?
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
JCvanDoorn
Sep 06, 2017Aspirant
Hi Streak2,
I have two satellites, but only one is connecting. The other just sits there with the solid white ring LED on.
I've now gone through a support case and it was determined that the unit was faulty and it will be replaced by Netgear.
Best regards and thanks for your time!
