Antipodeansam7
Aug 25, 2017Apprentice
ORBI Wifi Speed Drops
Hey Guys, So I have had my Orbi several months now. Every 3-4 weeks the wifi speed drops to below 30 mbs for download. However the speed test on the unit read 190 mps. The wired speeds also drop to e...
rickydphipps
Feb 08, 2018Star
It happened again to me after the latest firmware (V2.1.2.18). I'm getting close to dumping it.
Sady it's still rated #1 or 2 on most the the review sites. But the Linksys Velop is up there. If the next firmware update doesn't correct this, I am done with Netgear.
tony4069
Feb 09, 2018Aspirant
I’m having the same problem after 6 weeks of buying Orbi. Can’t believe that it can’t be fixed :(. All I would say is that the issue seems to affect a small number of users.
- rickydphippsFeb 20, 2018Star
I can't swear on the timing or even that the difference is real, but it seems since the last firmware update (V2.1.2.18), reboots seem to fix my speed problem. This has been true for the last two times I have tried it.
I had been skipping reboots altogether and going right to factory resets since earlier in the problem reboots did nothing to bring the speed back up from about 10% of my connection's rating on wifi.
Hopefully it is a real change and not just a couple flukes. This is way more tolerable.
I almost forgot... somewhere in there, I also unchecked all of the attached in Advanced Wireless settings.
