Antipodeansam7
Aug 25, 2017Apprentice
ORBI Wifi Speed Drops
Hey Guys, So I have had my Orbi several months now. Every 3-4 weeks the wifi speed drops to below 30 mbs for download. However the speed test on the unit read 190 mps. The wired speeds also drop to e...
tony4069
Feb 09, 2018Aspirant
I’m having the same problem after 6 weeks of buying Orbi. Can’t believe that it can’t be fixed :(. All I would say is that the issue seems to affect a small number of users.
rickydphipps
Feb 20, 2018Star
I can't swear on the timing or even that the difference is real, but it seems since the last firmware update (V2.1.2.18), reboots seem to fix my speed problem. This has been true for the last two times I have tried it.
I had been skipping reboots altogether and going right to factory resets since earlier in the problem reboots did nothing to bring the speed back up from about 10% of my connection's rating on wifi.
Hopefully it is a real change and not just a couple flukes. This is way more tolerable.
- rickydphippsFeb 20, 2018Star
I almost forgot... somewhere in there, I also unchecked all of the attached in Advanced Wireless settings.
