Antipodeansam7
Aug 25, 2017Apprentice
ORBI Wifi Speed Drops
Hey Guys, So I have had my Orbi several months now. Every 3-4 weeks the wifi speed drops to below 30 mbs for download. However the speed test on the unit read 190 mps. The wired speeds also drop to e...
Apr 30, 2018Guru - Experienced User
After resetting and checking speeds, your speeds are back for a period of time then drop?
Are you doing anything with QoS, Traffic Meter or Access Controls after resetting and speed testing?
- Antipodeansam7Apr 30, 2018ApprenticeYep exactly that, sometimes a few weeks, sometimes a couple of days, other times an hour. Nope I don’t touch anything in the interface after speeds are back up (I check using ookla), I know it has caused some people issues using the QoS and traffic.
