Antipodeansam7
Aug 25, 2017Apprentice
ORBI Wifi Speed Drops
Hey Guys, So I have had my Orbi several months now. Every 3-4 weeks the wifi speed drops to below 30 mbs for download. However the speed test on the unit read 190 mps. The wired speeds also drop to e...
Apr 30, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem/ONT?
rickydphipps
May 01, 2018Star
Thanks for the update, Antipodeansam7.
I'm really sorry to hear this continues to drag out for you. I hope they get it resolved. If they did, I wouldn't mind digging my Orbi out of the closet. The speeds was awesome when it worked. As of now the Eero Pro that I bought has been rock solid, though I have given up about 50-100Mbps of throughput. But at the end of the day, it's still plenty, and I will take that over dealing with -300Mbps every few days.
I'm still subscribed and watching, so I'd be grateful if you post your progress, even if you finally break down and replace the Orbi.
