Mach1ray
Oct 15, 2017Tutor
ORBI Wifi Speed Drops
I'm experiencing problems with the wifi dropping to 1/3 of it was after the setup. I reboot the router and all is fine for a while but then it reverts back to the same problem. I find myself rebootin...
Antipodeansam7
Oct 15, 2017Apprentice
I have been reporting the same problem for weeks now through several different lots of firmware, only short term fix is a hard reset, very frustrating
