Mach1ray
Oct 15, 2017Tutor
ORBI Wifi Speed Drops
I'm experiencing problems with the wifi dropping to 1/3 of it was after the setup. I reboot the router and all is fine for a while but then it reverts back to the same problem. I find myself rebootin...
DarrenM
Oct 17, 2017Sr. NETGEAR Moderator
Have you tried to enable beamforming and mumimo in the advanced wireless settings?
DarrenM
- Antipodeansam7Oct 17, 2017ApprenticeI have tried this with no change and also find that when the speed drops it effects wired as well, so not sure these would help regardless. How about you Mach?
