Mach1ray
Oct 15, 2017Tutor
ORBI Wifi Speed Drops
I'm experiencing problems with the wifi dropping to 1/3 of it was after the setup. I reboot the router and all is fine for a while but then it reverts back to the same problem. I find myself rebootin...
DarrenM
Oct 17, 2017Sr. NETGEAR Moderator
Have you tried to enable beamforming and mumimo in the advanced wireless settings?
DarrenM
Antipodeansam7
Oct 17, 2017Apprentice
I have tried this with no change and also find that when the speed drops it effects wired as well, so not sure these would help regardless. How about you Mach?
