ejstarky75
Aug 22, 2019Aspirant
Orbi Wifi Speed Limit RBK50
I have an Orbi RBK50. Works great. However, I recently went to 200Mbps on my internet speed through the cable company. My Orbi will not go past 100Mbps, my previous speed limit. The modem/router ...
- Aug 22, 2019
What is the Mfr and model# of the new modem? Just curious.
Glad the new modem fixed it. Please mark your thread and solved so others will know.Enjoy. :smileywink:
ekhalil
Aug 22, 2019Master
ejstarky75 wrote:........ My Orbi will not go past 100Mbps, my previous speed limit. ......
How do you make the test? Can it be that the computer you're making the test with has a Base 100 ethernet adapter?
- ejstarky75Aug 22, 2019Aspirant
Any of my laptops, iPad or iPhone get the same results 100Mbps. I got the 200 Mbs results on all of these devices using the cable company modem/router.
- FURRYe38Aug 22, 2019Guru - Experienced User
If your ISP modem has a built in router, please chose of the one of the posted suggested options to configure the modem for the Orbi router.
ejstarky75 wrote:Any of my laptops, iPad or iPhone get the same results 100Mbps. I got the 200 Mbs results on all of these devices using the cable company modem/router.
