ejstarky75
Aug 22, 2019Aspirant
Orbi Wifi Speed Limit RBK50
I have an Orbi RBK50. Works great. However, I recently went to 200Mbps on my internet speed through the cable company. My Orbi will not go past 100Mbps, my previous speed limit. The modem/router ...
- Aug 22, 2019
What is the Mfr and model# of the new modem? Just curious.
Glad the new modem fixed it. Please mark your thread and solved so others will know.Enjoy. :smileywink:
ejstarky75
V2.3.5.30 firmware
Arris DG3450A is the modem/router model. Had Motorola 8600 before but went back to cable and got TIvo. 8600 not Moca capable.
Home is 1052sq ft. Have satellite on the second floor not even 30 ft away from main router on 1st floor. Many neighbors near by as I live in asmall town. None have Orbi system. I will try changing channels and/or taking them off auto.
Beamforming, MIMO and WMM already enabled.
I will have to try the items to disable.
Thanks for all the help!
Aug 22, 2019Guru - Experienced User
Modem Combo Units: https://www.arris.com/products/touchstone-dg3450-cable-gateway
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- interestedpersoAug 22, 2019AspirantDont forget to turn of daisychain topology if you have the satalite connected via ethernet as i have noted such things with it on.
- ejstarky75Aug 22, 2019Aspirant
Daisy chaining is off right now along with all the suggestions from
FURRYe38 (Sensei) posted a new reply in Orbi on 2019-08-22 03:01 PM : Please see below. The only thing I can't find is circle to disable . Still 100 Mbps.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- FURRYe38Aug 22, 2019Guru - Experienced User
Depending up on how the modem is configured and which option you chose, I would probably factory reset the RBR and use a wired PC with the RBR. Power cycle off the modem for 30 seconds, then back on. Factory reset and RBR and walk thru the setup wizard. You can do this a couple of ways, bridge the modem fully, or keep the modem at router mode and configure the RBR for AP mode, then test speeds.
We can try option #2 later if you want too...
I already disable all the wifi radios on the modem/router combo previously. Still only get 100 Mbps. The day of the install last Friday, they were disable as I knew I wanted to still use my Netgear Orbi.
Disabling the wifi on the ISP modem may not be enough. The modem needs to be fully bridged, or try option #2 if you want to use the Orbi in router mode. If not, try the Orbi in AP mode with the ISP modem in router mode and see if this changes anything.
Try a wired PC with the back of the RBR first. I would leave off the RBS for time being until you get good speeds at the RBR.
