ejstarky75
Aug 22, 2019Aspirant
Orbi Wifi Speed Limit RBK50
I have an Orbi RBK50. Works great. However, I recently went to 200Mbps on my internet speed through the cable company. My Orbi will not go past 100Mbps, my previous speed limit. The modem/router ...
- Aug 23, 2019
What is the Mfr and model# of the new modem? Just curious.
Glad the new modem fixed it. Please mark your thread and solved so others will know.Enjoy. :smileywink:
ejstarky75
I already disable all the wifi radios on the modem/router combo previously. Still only get 100 Mbps. The day of the install last Friday, they were disable as I knew I wanted to still use my Netgear Orbi.
Aug 22, 2019Guru - Experienced User
Disabling the wifi on the ISP modem may not be enough. The modem needs to be fully bridged, or try option #2 if you want to use the Orbi in router mode. If not, try the Orbi in AP mode with the ISP modem in router mode and see if this changes anything.
Try a wired PC with the back of the RBR first. I would leave off the RBS for time being until you get good speeds at the RBR.
