danall22
Oct 07, 2018Aspirant
Orbi WiFi speed slow
Please help... I have the orbi rbk50 set up and was fine. However recently I have noticed the speed is slow. When I test in the orbi app it thinks it is 50mb but when I test on mobile I am getting abo...
ekhalil
Oct 07, 2018Master
- When measuruíng the speed on mobile, do you know if the mobile is connected to 5 GHz or 2.4 GHz? The 5GHz gives more bandwidth. Switch off Wifi and switch back on to change the band.
- Is the device you use for measuring connected to the router or the satellite? Do you see a difference if the device is connected to the router or the satellite?
- Does restarting the router/satellite improves anything?
- What device do you use for measurement? An iPhone?
- Do you see any difference if you get closer to the router/satellite?
danall22
When I measured the mobile was connected to 5ghz and was connected to the router. Seems to give a slight bit more when connected to the router rather than satellite but not much in it. Can get 20mb if I get right next to it but even that is no where near the 51 on wired and I used to get 50odd on wireless anywhere in the house! I am using android to measure.
- FURRYe38Oct 07, 2018Guru - Experienced User
Test with other devices if you can to compare.
danall22 wrote:
When I measured the mobile was connected to 5ghz and was connected to the router. Seems to give a slight bit more when connected to the router rather than satellite but not much in it. Can get 20mb if I get right next to it but even that is no where near the 51 on wired and I used to get 50odd on wireless anywhere in the house! I am using android to measure.- danall22Oct 07, 2018AspirantTested with iPad and different android phone and still the same on all 3.
