danall22
Oct 07, 2018Aspirant
Orbi WiFi speed slow
Please help... I have the orbi rbk50 set up and was fine. However recently I have noticed the speed is slow. When I test in the orbi app it thinks it is 50mb but when I test on mobile I am getting abo...
Oct 07, 2018Guru - Experienced User
WMM should be enabled most of the time.
cahiatt wrote:
I had a similar issue today playing with settings. I'm on a gig connection and could get no better than about 21meg or up on any wireless device. While toying with wifi power, channels and other settings I had turned OFF the WMM (wi-fi multimedia settings) under Advanced, Wireless Settings for both 2.4 and 5ghz channels. Not sure why but once I turned this off my wi-fi bandwidth just wouldn't go past about 20meg. Turned WMM back on and am getting about 400 meg on my cell phone now.
Check you WMM status also and switch it to see if it changes anything.
danall22
Ok...an update... So I plugged the ethernet cable into my routerand solid upload but then I plugged it into the main orbi which is connected to my router and it have the same poor download speed which must mean it is the router that is at fault here then? Maybe a new router would fix it or replace with modem and have orbi be the router?
- FURRYe38Oct 07, 2018Guru - Experienced User
If you have a router infront of the Orbi, this would be a problem...
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
danall22 wrote:
Ok...an update... So I plugged the ethernet cable into my routerand solid upload but then I plugged it into the main orbi which is connected to my router and it have the same poor download speed which must mean it is the router that is at fault here then? Maybe a new router would fix it or replace with modem and have orbi be the router? - ekhalilOct 07, 2018MasterIt can also be a software issue. Try to eliminate this option before considering HW changes:
- Have you tried to restart the router and see if this will improve anything?
- Try a factory reset to remove any data corruption - FURRYe38Oct 07, 2018Guru - Experienced User
This would not be a SW issue...lets get the modem configured for one of the options...Then go from there.
- danall22Oct 08, 2018AspirantMy set up is already as number 3, my router has WiFi off and the orbi is in ap mode connected to the router via ethernet.
It is now making me think there is something wrong with the orbi then as the router is suppling the 50mb but that is not coming out of the orbi. I will try resetting but I did do that yesterday with no luck.
Or could it be the router? At least I have established the issue is not WiFi. - FURRYe38Oct 08, 2018Guru - Experienced User
Has the Modem been powered off then back on along with the Orbi?
I would try option #2 in the suggestion list about your modem.
