Diesel26's avatar
Diesel26
Orbi WiFi Speed
Hello,
I had new internet service installed today (300 Down / 20 Up).  Speed tests from the Orbi app and hardwired to the router show great speeds.  However, when I run any kind of speed test when connected to WiFi, the best download speed I can get is 13MB.  This is from broth iPhones and laptops.  Both Beamforming and Mu-MIMO are enabled.
Not sure if there is a problem with a setting or if this is related to a firmware issue.  Current firmware is 2.1.2.18.
Any help is appreciated.
Thanks,
Ben
  • I was able to resolve the problem on my own.
    ADVANCED -> ADVANCED SETUP -> Enable WMM
    Somehow multimedia settings enable more bandwidth?
    • linkwrt's avatar
      linkwrt
      Guide
      WMM is enabled by default.
      You should not disable WMM.
  • I have 1000mbps .
    And i don't have any issue.
    280mbps iphone se
    590mbps macbook air.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to remove all device from the wifi and then connect just 1 device and test the speed? it could be some older wifi device slowing the network down.
    DarrenM
