Lylemats
Sep 16, 2020Tutor
ORBI Wifi speeds slow
I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed...
- Sep 22, 2020
Be sure to do a backup configuration to file for safe keeping. This saves time if a reset is needed later on again. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Sep 22, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
ChloeJ wrote:I have the exact same issue. It just started last week. I had no issues prior. Were you able to resolve it?
Lylemats
Sep 22, 2020Tutor
Aloha
i did a factory reset and speed came back. Don't know why I didn't think of that earlier
thanks
lyle
- FURRYe38Sep 22, 2020Guru - Experienced User
Enjoy. :smileywink:
