Lylemats
Sep 16, 2020Tutor
ORBI Wifi speeds slow
I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed...
- Sep 22, 2020
Be sure to do a backup configuration to file for safe keeping. This saves time if a reset is needed later on again. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Lylemats
Sep 22, 2020Tutor
Aloha
i did a factory reset and speed came back. Don't know why I didn't think of that earlier
thanks
lyle
Sep 22, 2020Guru - Experienced User
Enjoy. :smileywink:
