Lylemats
Sep 16, 2020Tutor
ORBI Wifi speeds slow
I have an ORBI RBR 50 and used to get 300 dl speeds over the air and the speed matched if i did it thru the app. Recently the speed thru the app is still the same 200-300 dl but if i check the speed...
- Sep 22, 2020
Be sure to do a backup configuration to file for safe keeping. This saves time if a reset is needed later on again. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
ChloeJ
Sep 22, 2020Initiate
I have the exact same issue. It just started last week. I had no issues prior. Were you able to resolve it?
ChloeJ
I had already ensure mosted current firmware and reset the main and satellite and went through the setup again - that did not help. I had noticed my satellite connection was at 2.4GHZ, tried changing the channel for 5GHZ and that seemed to help - my issue was only devices connected to the satellite. So far so good.
- FURRYe38Sep 23, 2020Guru - Experienced User
Enjoy. :smileywink:
