photoliv41's avatar
Jan 01, 2017
Orbi WiFi System Compatibility
How do I know if the Orbi WiFi System is compatible with my devices?
  • Wifi is an interoperablity standard.  As long as your devices were certified they should work.  The orbi supports G / N / AC standards so as long as your devices are complient with one of those you should be ok.  Here is a good article on 802.11 Wireless standards:
    https://en.wikipedia.org/wiki/IEEE_802.11
    • photoliv41's avatar
      photoliv41
      Tutor
      I appreciate your answer, unfortunately I'm no techy.  I don't know how to tell if my devices are "certified" or what that means.  The article you gave me a link to is over my head as well.  The terminology is totally foreign to me.  Is there someone who can explain this to me in Layman's terms please?
      • netwrks's avatar
        netwrks
        Master
        In Layman's terms, yes, it works.. There's lots of reading material out on the big bad Internet.. Fishing vs Fish.
