elementoulis
Dec 18, 2019Aspirant
Orbi wifi system details
Hi, I am looking to join the Orbi family. However I get really frustrated and confused with how products are laid out in the website. Can someone explain the logic behind the naming convention and i...
- Dec 19, 2019
If it is down to the number of satellites, unless you save a lot by buying a bundle, start with the smallest number that makes sense and then add more if you find you have "not spots". If you want to add wired connections, think Powerline Ethernet.
One important aspect for those things is also the hardware part - I often like to take a look at the CPU manufacturer and the amount of RAM as well as its tier (if its DDR3 or DDR4). Where could I find all these?
The only place where Netgear posts any details is in the data sheets on the support pages for each device.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
Or go out into the Internet. Many of these details probably come under the "trade secret" category.
elementoulis
Dec 20, 2019Aspirant
Okay I've done some more reading. Is there any place I can get a full knowledge and feel of the web-based management interface for the Orbi? And does that interface diferfentiate in any way between versions (i.e. RBK10 to 20 to 50 etc.)
Thanks in advance,
George
CrimpOn
Dec 20, 2019Guru - Experienced User
This one is easier to answer. The User Guide for Orbi is here: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
