anhome
Apr 08, 2020Aspirant
Orbi WiFi System (RBK13) AC1200 vs RBK22 — Orbi AC2200 Tri-band WiFi System
which one is better? Orbi WiFi System (RBK13) AC1200 vs RBK22 — Orbi AC2200 Tri-band WiFi System I have a 4500 sqft home with 15 devices. Best an
Apr 09, 2020Guru - Experienced User
I would run thru the find your system based on your home size to see what would be best:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
Size of home and placement will be key to ensuring an Orbi system will work well for you.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
