Zeegs
Jun 02, 2019Aspirant
Orbi WiFi System (RBK30)
Why does my wifi extender regularly go “Magenta”? Every few days I have to reset it by powering off. What causes it?
Jun 07, 2019Guru - Experienced User
Possible interferences or placement configuration could be a cause.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- ZeegsJun 07, 2019Aspirant
I use an orbi RBR50 as the base router/AP. Have not touched the firmware since delivery. The satellite is about 20 feet from the router.
