TeslaZ
Nov 26, 2018Follower
Orbi WiFi System (RBK50) AC3000
Folks,
Looking for some options with a new WiFi system.
I have a fairly complex home network with DSL (yes I know its all thats availabe in my area) and a router that is currently forward por...
RocketSquirrel
Nov 26, 2018Luminary
The RBK50 works fine in AP mode. IMHO, it works better as an AP than as a router. I found its routing abilities inferior to my Asus AC68U, so I continue to use that as a router with its wifi turned off. I have no issues with my 3 hard-wired Orbis. My mobile devices hand off smoothly as they move around the house.
If you read through this forum, people's experiences vary a lot, sometimes inexplicably. You may get lucky or unlucky. If you decide to try Orbi, I recommend buying from whichever retailer offers the longest return period.
