ssoleymani
Jun 04, 2018Follower
Orbi WiFi System (RBK53)- Apple IOS issues ???
I am interested in the AC3000 Tribad system. Being a Costco memeber and their great return policy and prices doesnt hurt. But i keep seeing reviews about this system having issues with IOS be it ta...
Jun 04, 2018Guru - Experienced User
There seems to have a mix of work and non working users with iOS devices.
I have a 40 series system and it's been working well for me and my iOS devices.
Beamforming is only enabled. MIMO is disabled and seems to play a role in there systems. Some say it's not working right or some devices are not compatible with it. Daisy Chain is not needed unless you have two or more satellites configured to connect to each other. Fast Roaming has been known to play a roll as well. So it's disabled.
Also known issues with iOS itself in recent versions, something to do a search on and look at that information.
You can try one out and see. If not, then you can return it.
