Linda-in-Texas
Jan 26, 2019Aspirant
Orbi WiFi System (RBK53) AC3000 - Can no longer update or download via Orbi
Background:
I have U-Verse TV and internet. We purchased Orbi, because AT&T wifi only covered about one half of our house. I installed Orbi, and it worked great for over a year. At that time U-V...
Jan 26, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router, if so, you maybe in a double NAT condition which will cause problems and is not recommended.
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying option #3 first...this will disable the router and some features on the Orbi so you'll need to use the modem as your router. Disable ALL wiress radios on the ISP modem.
Linda-in-Texas wrote:
Background:
I have U-Verse TV and internet. We purchased Orbi, because AT&T wifi only covered about one half of our house. I installed Orbi, and it worked great for over a year. At that time U-Verse TV and internet became inoperative, and AT&T came out and replaced the AT&T modem. All of the TV’s, computers, iPads and iPhones were updated to the new ATT&T wifi network name. The wireless items were also updated with the new Netgear password that I had to create during that time.
Problem:
I thought that everything was working fine, until I realized when using Orbi I could not update the iOS on my phone or iPad or TV connected to Orbi. I also could not download anything from the internet. I now have to switch to the AT&T wifi to do updates and downloads.
I feel like the problem is some simple setting or solution, but I don’t know what it is. Can somebody help!
