Linda-in-Texas
Jan 26, 2019Aspirant
Orbi WiFi System (RBK53) AC3000 - Can no longer update or download via Orbi
Background:
I have U-Verse TV and internet. We purchased Orbi, because AT&T wifi only covered about one half of our house. I installed Orbi, and it worked great for over a year. At that time U-V...
Linda-in-Texas
Thank you FURRYe38 for your quick response and information.
Answers to your questions:
Firmware of the Orbi is 2.2.1.210
The new AT&T modem that Orbi is connected to is ARRIS BGW210-700 (dated 9-3-2018). The ARRIS has four Ethernet ports on the back. One goes the Wireless Access Point Cisco VEN501-AT, another to the Orbi and another goes to the 16-port NG switch (mentioned in the next paragraph). Another line from the WAP is connected at a ONT port on the ARRIS.
On November 30, I installed a new Netgear GS316-100NAS 16-port Gigabit Ethernet Unmanaged Switch, which is also connected to the ARRIS. I do not think that this had an impact on my issue, but I thought is was worth mentioning.
Please let me know how this additional information impacts your previous reply or if you have additional solutions.
- FURRYe38Jan 26, 2019Guru - Experienced User
Ok, so your modem already has a built in router.
Here some options to help you get the Orbi connected better with the modem:
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying #3 first...
