Saved
Apr 03, 2018Aspirant
Orbi WiFi System RBK53 firmware 2.1.2.18 doesn't auto update to 2.1.3.4
Saved
Thanks for your reply. By the time I initiated the post, I had already done a manual update with Google Chrome, but without a factory reset.
I had basically created this post to let the community and Netgear tech support know that the firmware version 2.1.2.18 was not auto updating & therefore it could also be a problem that would be transfered to the new firmware version 2.1.3.4,
I figured Netgear probably did not consider fixing the Auto Update problem as they were creating the new firmware 2.1.3.4, due to possibly not being aware that such problem even existed.
Apr 03, 2018Guru - Experienced User
Please do a full factory reset on the system and set up from scratch.
Savedwrote:Thanks for your reply. By the time I initiated the post, I had already done a manual update with Google Chrome, but without a factory reset.
