Cbrian
Aug 16, 2017Follower
Orbi WiFi System (RBK53) Power supply
Are the 110v US power adapters supplied as part of the Orbi RBK53 solution designed to also work with the 240V UK power system. I appreciate a different plug is required to convert from the US 2 pin...
- Aug 16, 2017
Yes. At least for the RBK50, the input is 110-240V 50/60Hz.
st_shaw
Aug 16, 2017Master
