karnekaren
Oct 26, 2020Aspirant
Orbi WiFi System showing 404 error
My router and two satelittes were doing very well until about a month ago. Possibly a power surge threw off the satelittes. Now, I am getting 404 errors on my iphone 10 when I am on wifi. It occurs...
- Oct 26, 2020
You model modem has a built in router and wifi. What mode is the modem working in? Modem only mode or router mode. If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Oct 26, 2020Guru - Experienced User
Couple of options,
karnekaren
Oct 27, 2020Aspirant
I had set up my modem as a bridge. Thank you for the information.
Actually, a previous post suggesting that I give a one minute time to reboot if what fixed the problem
Thank you.
- FURRYe38Oct 27, 2020Guru - Experienced User
Enjoy. :smileywink:
