jasonwong
Nov 25, 2018Aspirant
Orbi wifi system SSID issue
HI,
I am going to buy Orbi wifi system, I heard that two or three satellite will have one SSID and users can use unique SSID in house, but how about one frequency for one SSID?
in traditional dua...
- Nov 25, 2018
The idea behind a mesh system like Orbi is to have a single SSID for all base stations and all radio bands,
Devices will see this common SSID and select the band that has better signal stranget (RSSI) in the position where the device is located.
In theory you should not tell the device which band to select, it will automatically select the most suitable one.
ekhalil
Nov 25, 2018Master
- jasonwongNov 25, 2018Aspirant
Thanks ekhalil.
