blue_sky
Apr 27, 2018Aspirant
Orbi WiFi System wifi backhaul poor
RBR 50 with 1 statellite
Firmware V2.1.4.10 on both
2 Questions:
1.While speedtest in the orbi app shows 90Mbps upload and 90Mbps download, when I check on speedtest app on the same android ph...
Aug 19, 2018Guru - Experienced User
Possilbe speed differences between wifi mobile and apps...and the device. Possible problem with the app...
- Carbuff2Aug 19, 2018Aspirant
Are you saying that the ORBI app doesn't measure speed on the actual phone? That it measures something internal and then reports the speed to the ORBI app?
If so, that might explain the discrepancy...
