kk4mx's avatar
kk4mx
Orbi WiFi System
I am using AT&T U-verse 18mb dl.  The modem is an NVG589.  I have had pauses and delays in opening a web site, google, etc. for some time now.  Have several devices, never more than 2 on line simitai...
  • DarrenM's avatar
    Sep 15, 2016
    Hello kk4mx
    That is hard to answer because if its a internet issue then it would still happen on any router but Orbi will make using wireless easy  as it will make 1 network in your home no need for switching networks and the router will hand your devices off to the best wifi signal when moving around the home.
    DarrenM
