jdstephe
Oct 09, 2016Tutor
Orbi WiFi System
I seem to be getting modulation of my Orbi router for what appears to be the 2.4GHz network on Channel 8. Both my base and satellite are exhibiting the same behavior. I have signal strengths that pu...
itGeeks
Oct 10, 2016Apprentice
Other then what petey said did you turn off the wireess on the U-Verse router? If not now is a good time to do it.
