jimv64's avatar
jimv64
Follower
Dec 09, 2016
Orbi WiFi System
will the orbi system be nbn compatible?
1 Reply
    hi
    the term NBN is specific to australia i believe , eg its called just fiber in other countries or vdsl , depending on what type of NBN you have
    fttn is where the internet still uses the phone line and connects to whats called vdsl
    fttp is where the tech comes in and installes whats called a NTD in your house and you connect ethernet to it
    and there are a few other types called fixed wireless and sat and hfc all known as NBN in OZ
    so the orbi can connect to
    fttp direct ( if home phone isnt needed )
    fttn needs a vdsl modem and then you can connect the orbi behind it
    for more info on aussie NBN you should go to the australian broadband forun called whirlpool forums
    https://forums.whirlpool.net.au/
    and specifically the orbi thread
    NETGEAR Introduces Orbi Wi-Fi Mesh system
    https://forums.whirlpool.net.au/forum-replies.cfm?t=2559904
    pete
    as many factors errect australian broadband and the many ways it connects
    pete
    btw you will find me on the modem / router section of whirlpool forum , i just dont want to confuse these forums with the connectivity specific to australia
