MiTn
Jan 01, 2017Tutor
Orbi WiFi System
Has anyone had issues with trying to get PyleCam 8 work with Orbi?
JMU1998
Jan 01, 2017Luminary
I think Nestcams have issues with beamforming which Netgear Engineering is looking into to address hopefully in next Firmware release.
MiTn
Jan 04, 2017Tutor
Is this an issue with all net security cams or just Pyle?
- MiTnJan 04, 2017Tutor
Just checked my and wasn't able to connect with my logitech Vid HD camera that I use for Skype, too.
- Mikey94025Jan 04, 2017Hero
Logitech Vid HD is a software program, as is Skype... What wifi camera are you trying to connect (directly) to Orbi?
The issues some devices have, like Nest cameras and Ring doorbells, are that they intermittently disconnect (they monitor for constant wifi connection). AFAIK disabling beamforming allows these devices to work correctly for most people, though some still report connectivity issues. I personally have had zero connectivity drops in December with my 4 Dropcam/Nest cameras after disabling beamforming.
I anecdotally didn't notice any performance differences with beamforming off. Since it's a new feature that most routers haven't had, I also don't miss it. I wouldn't hold out on a fix from Netgear because it might also be something on the Nest/Ring software side.
How do you turn beamforming off?
