Leimam
Jan 22, 2017Aspirant
Orbi WiFi System
Hi guys. I'm thinking of buying an orbi wifi system. Can I use it with the Technicolor TG784n v3 Gateway installed by my Internet provider? I would appreciate any advice you can give me. Thanks.
DarrenM
Jan 24, 2017Sr. NETGEAR Moderator
Hello Leumam
Yes you can either bridge the gateway to be a modem only or you can run Orbi as a Access point.
DarrenM
- LeimamJan 25, 2017Aspirant
Hi Darren. Thanks for the reply.
What´s the difference between the two?
Should I turn off the wifi on the technicolor gateway?
Thanks.
Leimam.
- DarrenMJan 27, 2017Sr. NETGEAR Moderator
Hello Leimam
That would be the best option is to make the Technicolor in modem only mode.
DarrenM
