Leimam
Jan 22, 2017Aspirant
Orbi WiFi System
Hi guys. I'm thinking of buying an orbi wifi system. Can I use it with the Technicolor TG784n v3 Gateway installed by my Internet provider? I would appreciate any advice you can give me. Thanks.
Leimam
Jan 25, 2017Aspirant
Hi Darren. Thanks for the reply.
What´s the difference between the two?
Should I turn off the wifi on the technicolor gateway?
Thanks.
Leimam.
DarrenM
Jan 27, 2017Sr. NETGEAR Moderator
Hello Leimam
That would be the best option is to make the Technicolor in modem only mode.
DarrenM
